Hi,
I noticed in this forum many competent people on this subject so I am writing hoping someone might know and help.
I have Ezee Sprint for over 7 years, actively driven it in snow and rain, all year round (Finland). It didn't have easy time with me
Now recently, it started making troubles, motor not starting rotating in every occasion, sometimes works and when it works it rides with no problems but sometimes it doesn't start no matter you do.
Trying to cope with it I cleaned and checked the throttle, cables but found no problems.
Then after I disabled the pedal sensor I managed to find the temporary cure in case motor doesn't start rotating the wheel.
When I switch on the controller (LED lights up showing no problems) and if throttle doesn't start the motor (remember I disabled pedal sensor) I bring the front fork up enough that the wheel is above the ground and while I keep throttle twisted lightly I rotate the front wheel backwards a little bit. The motor opposes to it and jerks the wheel very little to the front. Couple of times like that (I am guessing: depending on the wheel position) and the motor starts rotating the wheel. After that the motor runs with no problems. Stopping doesn't affect it, switching off doesn't bother either, it just works, which confuses me.
When I reach the destination and leave the bike, next day I switch it on the probability that it won't start at once is around 80%.
I was guessing the hall sensor but I never opened the motor so I am not sure if that would bring me any nearer.
Is there anyone who recognizes something familiar in this behavior and could lead me where to start "digging"?
Thanks for any help in advance!
Babo
Babo
