cowrevenge
New here
- Joined
- Aug 27, 2020
- Messages
- 14
I ran a TSDZ2 on my old bike for a few years and loved it, but when i built my new bike, decided to try out the TSDZ2B w/ brass.
Its been pretty trash since day 1, but I stuck with it since I spent so much money. This week I decided to swap out the brass for white gear to see if I could solve some of strange problems. (Hard pedaling/strange noises, etc etc)
However, when i swapped the gear, the Torque stopped working. It works if i bridge the connector OR if I unplug the sensor and then plug it back in after startup.
After fighting with it a few days, I decided to swap in the torque sensor from my other bike, but it still has the exact same problem. So its gotta be in the controller randomly going bad for no reason at all.
So. Throttle works, Walk works, Torque works if I use a resistor, or unplug it before start up then replug it. Swapping the Sensor results in same issue.
1. Its a VLCD6, .. Is there a way to calibrate the sensor on this display?
2. I have a 860C V1.6 and a CP2102, but for the life of me cant the api bootloader on this thing. (even then how do i know i can flash the tsdbz2 controller?) I was planning on putting this on my old bike, but never flashed them after wiring it up. Im seeing TX/RX, and pushing the power button pauses it, but it doesn't ever leave the wait state, possible due to bad firmware?
3. Since I suspect the issue is somehow in the controller but i cant figure out how this could have even remotely happened... do i cry and just spend $150 on a preflashed OSF controller and 860C, then try and save this horrible lemon TSDZB2.
4. Last question.. the meter reads 12V on the sensor connector.. is this correct? should it be 5V?
