liveforphysics said:
Size the lipo correctly. A 10kw-hrs pack of Nano-tech's can discharge at 1MW (1300HP), continuously charge at 100kw, and could burst regen at 200kw. And 10kwhr is a pretty damn small pack for any non-bicycle EV.
Exactly Luke, this is the point ...
regen rate is the critical determining factor and is at best 5 times longer than discharge rate, so for a KERS system used in a race ..( it has to regen the same amount as used each lap ?) .. where regen time is limited to braking periods , and F1 braking periods are very short ,.. probably only 10sec per lap available for max regen.
So they either have only 1 or 2 seconds of KERS boost per lap, or they have to use a much bigger battery than is actually needed for discharge capacity , just so they can regen sufficiently.
The F1 KERS actually need very little CAPACITY...
EG: lets assume they run a 375 volt system, and its capable of 60kW boost for 6 secs
( = 160A discharge, but only 0.10 kWhr capacity needed!)
Using known available Nanotech lipo (HK) , this could easily be done with 25 of the 4S, 2.2 Ahr packs, (=only 0.825 kWhr ?).
.. with a total weight of 7.8 kg. ( F1 teams probably have smaller Ahr high discharge packs of lower weight)
BUT, even at 20C charge rate (= 44A ) , you will need 22 secs of regen to recover that 0.1kWhr ...even at 100% eff !
Thats more than 2 laps worth of braking to regen the power used in one 6 sec boost !
The alternative would be to use a pack of more than double the size to be able to regen within the braking time available in one lap. ... but that would be extra weight to carry .
