The voltage goes up a little.i dont have anything on the kickstandWhat happens in the Graph when you twist the throttle, does it show any voltage readings from the throttle?
What happens when you brake or use the side stand?
It sounds just like you have the brake signal enabled.Hi I have a fardriver controller worked great. Now all it does is beep when I turn the throttle. I change the throttle and the same. I tried to relearn the controller but it wont let me. Is it the controller or my hub motor
Could you share a screenshot of all the parameters you set up so we could try to diagnose better?Just tried same thing a beep. The red exclamation mark is on even in drive
can you tell what wires from controller you have connected to side stand? i wired mine so that it disconnectes 12v power to main relay , because i did not know better.Here the pictures from my Controller
Ready to run
Brake or sidestand activated.
