I don't think scaling it down will help with the simulation.Farfle said:I wonder if scaling it down would at least get me in the ballpark with magnet coverage for a given stator configuration, and then I can refine the flux densities in FEMM.
If you run 2 in series you get a little more inductance than a Colossus.Farfle said:hmm, emetor is spitting out 0.005797 mH or 5.7uh. thats really really really low. bugger.
Back to the drawing board!
(I can not actually simulate this one, but its a WAG based on tests of 12t 8p and 12t 16p)
I think it's just the single winding symmetry.bearing said:It fails? does it give a reason?
Miles said:I think it's just the single winding symmetry.bearing said:It fails? does it give a reason?
24t 20p has two symmetries. 24t 22p, which has only one, fails for me.bearing said:Miles said:I think it's just the single winding symmetry.bearing said:It fails? does it give a reason?
20p24t worked for me (at least the load sim), so this should work. Or am I wrong?
bearing said:Farfle, are you using single or double layer windings?
Double layer seems to simulated easier as well.
A single layer 12t 10p has quite a dominant sub-harmonic, too......Farfle said:I think I have a final design. Its 12t 10p in a dual-layer configuration
So, a nice round target of 100Nm to meet the Challenge...Farfle said:so probably 65lbs when copper, axle/bearings and sideplate go on.
Something like this...Miles said:Just a small suggestion: Assuming the rotor is laminated, you could give it a more rigid structural form. Bearing in mind the single symmetry and relatively high speed......
Miles said:24t 20p has two symmetries. 24t 22p, which has only one, fails for me.
Have you done it since the changes to the airgap meshing, though?bearing said:I have been able to simulate 8p9t, which has only one winding symmetry.
bearing said:I didn't know about an airgap meshing change.
bearing said:So you are the evil behind this!
:lol:
Miles said:What will you use for the stator/rotor laminations? Have you had a quote for Hiperco 50?
Miles said:So, a nice round target of 100Nm to meet the Challenge...Farfle said:so probably 65lbs when copper, axle/bearings and sideplate go on.
I doubt it will make a major difference and it's heat generated within the magnets themselves that is the greater threat..... You're segmenting the magnets circumferentially. How about axially?Farfle said:I am wondering if the back iron needs to be laminated, and if it doesn't, I would machine it from a single piece of 12" dia, .5"wall 1018 tubing (304.8mm dia x12.5mm wall. Which is actually pretty cheap.
Miles said:I doubt it will make a major difference and it's heat generated within the magnets themselves that is the greater threat..... You're segmenting the magnets circumferentially. How about axially?
The worst of the sub-harmonics is cancelled out in 3 phase:
