Farfle
The links don't seem to be visible on my end. The only way I have been able to share something from emetor is to screenshot it.
Oh....They show for me. I'll do a screencap.Farfle said:The links don't seem to be visible on my end. The only way I have been able to share something from emetor is to screenshot it.
That was supposed to be good news :lol: You have to compare the 3 phase MMF spectrums.Farfle said:Yeah, looks like magnet losses will need to be mitigated with a spectrum so similar to that guy .
Epoxy coated, instead of plating?Farfle said:Small segments, and maybe an electrically insulating coating?
Miles said:Epoxy coated, instead of plating?Farfle said:Small segments, and maybe an electrically insulating coating?
mauimart said:Just stumbled across this Formula Student racer http://www.amzracing.ch/en/cars which is powered with a 'home built' outunner similar to what your specs call for. Not much detail given other than the weight is 4.6 kg and power output is 37kW (seems a bit high if you ask me).
bearing said:85kW is the nominal limit? there is no limit of peak power?
In this case they have almost 150kW peak power. Seems unfair to the ICE competition. How do they check the nominal limit?
Anyway, looks like a great motor. But it probably runs above 400Hz, which I believe is what's limiting Farfle's motor, because of the controller.
Farfle said:I will probably use the 1000A 120v kelly,
liveforphysics said:Farfle said:I will probably use the 1000A 120v kelly,
Just as a datapoint, when we swapped from a size6 to the biggest Kelly controller made that claimed 1000A phase current controller with ultra-high-speed firmware, it blew up in under 2mins of gentle dyno testing, and never was able to make the power of the size6 before it exploded. It was also about 1.5-2ft long and maybe 25lbs.
Just because Kelly writes many zeros on the datasheet doesn't mean it actually works unfortunately.
Farfle said:That really is a shame. After seeing what Ripperton had done with his twin Kellys, I was hoping the newer models were getting better. :x . Looks like low pole count and maybe twin size 4 Sevcons are the only doable option.
[/quote]Farfle said:The Scott drive controller would be the only other option in that power range that is sub $4k, but 400V scares the crap outta me, and is still expensive. I am hoping to keep the powertrain under $7k
Timmey said:bearing said:85kW is the nominal limit? there is no limit of peak power?
85 kW peak
Miles said:Why the single layer winding?
