I can see why regen braking can be unpopular. I am currently waiting for a fixed clutch geared hub motor to be available within the next 6 months to solve the weight problem, as the large direct drive motors are indeed heavy.
However as for pedaling with the motor off, I've done it a few times and it's honestly not that bad compared to no wheel, with the obvious problem of not being able to go 20+ mph. I've noticed that the increase in resistance tends to increase much more rapidly after 15 mph, but I've been able to maintain 15. With the setup I have my motor computer automatically decreases power draw so that the motor is always energized even at very low voltages, giving a constant 10-20 watts on what would be an otherwise dead battery.
With the motor controller I have, I have the option to add in "virtual freewheeling" which gives out about 25 watts at all times while the wheel is in motion, which actually makes it "freewheel" more than a plain wheel would be. The only downside I've noticed is that the motor is continuing to run even when I stop pedaling, and without the pedal and crank noise to mask it, I can just barely hear the whine of the motor at lower speeds like 5 mph.
I'm doing everything to mitigate the disadvantages and get my benefit; an 17% increase in range, which is just enough to get me through my commute. If I didn't have as much stop and go traffic, then I can see why this would be not as big of an advantage for other riders.
