Still testing.
I think I want to try a redesigned version in hopes of getting rid of the little glitch when you power up.
Other than that, it's pretty cool. If I give about 1/2 throttle, I goes up to 20 amps and stays rock solid until (or if) I build up enough speed for the amps to drop. Twist the throttle more, you get more amps.
The range of adjustment for the maximum current is not correct right now, so the redesigned one should have a more adjustable range.
