999zip999
100 TW
Wesnewell how much do you have in chargers, power supply, monitors, wires, connectors and batteries? For a setup ?
I paid $179 for the Hyperion 1420i about 19 months ago. You can get it now for a lot less.999zip999 said:Wesnewell how much do you have in chargers, power supply, monitors, wires, connectors and batteries? For a setup ?
wesnewell said:I paid $179 for the Hyperion 1420i about 19 months ago. You can get it now for a lot less.999zip999 said:Wesnewell how much do you have in chargers, power supply, monitors, wires, connectors and batteries? For a setup ?
Used 24V 600W power supply I lucked out on. $21 shipped.
1 to 6 charge and balance cables, under $20
Battery= 12 5ah 4s hard case packs at ~$22 each. Maybe $300 with optional wiring to parallel balance plugs as 24s2p.
There is no wiring needed for the battery itself. Just break the connectors that come on the packs and plug them in in series leaving a positive red at one end and a negative black at the other. The kit you buy should have a cable from the controller to the battery pack. I highly suggest you use a spark prevention circuit in between. Here's my old 18s2p setup. I think it's clear enough to make out how the wire 6 packs as 12s2p. Click to enlarge.zjhost said:Did you do the wiring for the batteries yourself? I can't find any series of parallel connectors other than the 14awg from hobbyking. With those connectors it would be a lot easier. But most people say I need at least 12awg wire. It won't be a big problem or anything, a friend of mine has a lot of experience with electronics. But yeah I prefer the pre-made ones..
RyanTo said:I think it looks alright I don't see why you'll need these: If you already have the cellog.
e. 6x Battery Monitor 2-6S
You can just check them with the cellog one pack at a time every once in awhile. It's pretty easy and I do it with my 10 6s packs on ocassion. You can plug the cellog into one pack and that'll give you a good idea of how the others are doing, if you want to check it when you're riding. Mine have stayed in sync.
RyanTo said:I agree with the others that you should get a different charger maybe an iCharger and powersupply. That way you can charge it in an hour or two. You can also set it to 4.1 volt max to extend your battery life. (my other cheepo one doesn't)
http://epbuddy.com/index.php?main_page=product_info&cPath=17_20&products_id=169
I would really try to decide on your configuration and get a SP wiring setup like iceman does. You can also build it yourself. Maybe decide what your configuration (12s, 16s, 20s, etc) will be after you try it out. When you're hooking up and breaking down the pack for charging be extra carefull as that's when you'll cross/mixup wires without a good series parallel plug and play setup.
Yes the rear wheel. Does the prokit 901 has premade holes for a disc brake, there weren't any on the 3d drawing. I am using a hydrolic disc brake caliper. But if it doesn't fit I will use a spacer to get more space, and maybe even convert to a 1 speed sprocket in the back to get more space (if necessary)Punx0r said:Are you looking at the rear wheel prokit 901? If so, I was able to fit my mechanical disc brake by inserting a spacer between the disc and motor to give the caliper enough space (so it didn't touch the motor).
Punx0r said:Yes, the motor has a male thread that took the disc adapter from my original rear wheel. I put a ~3mm spacer between this and the motor, then used washers between the caliper and bike frame to correctly position the caliper on the disc.
My freewheel was only 6 speed, so fitted fairly easily.
dogman said:Your 9 speed cassete will not fit the motor. You will need a 5 -7 speed screw on freewheel.
You can use a high power charger with a lower power power suppy. Just don't pull more than the rating of the power supply. Adjust the charger by setting the amps it charges at low enough. Later on, as funds are more avaliable, you could get a more powerful power suppy to charge even faster.
wesnewell said:Most rear wheel kits come with a 5-7 speed freewheel. Just use it.
