Dogman Dan has touched on the key points you want to follow,
to add to that.
I have experience with two hub motors, one small one, that you should not even consider unless you are very fit , a 36 volt /350 watt rated motor that I run at 48 volts,
and
The better choice for you , only if you do go with a hub motor , the Mac motor from em3ev.com
the Mac I have is a fast wind ( 6T ) and will go up hills, on a 48 volt battery pack, but it liked to go up hills less than 14% grade, ( 48 volt battery pack 11.5 amp hours = apx. 520 watt hours )
and even then it only liked to go up hills when I used 22-25 amps into the motor , meaning with a 48 volt pack the motor was now running at 1,056 watts to 1,200 watts .
for your hills in your area , you would want the ( 12 T ) version of the Mac motor. If you do go with a hub motor it is best if you know someone who can build/lace up a wheel for you, and true it , dish it, and take out any hop of the rim.
However
For where you live the BBS02 or BBSHD would be better. Luna Cycles LLC in the Los Angeles area has those.
Because of the distance you want to go, you should really only use a 48 volt or 52 volt battery pack, and one that is at least 13 amp hours. or in other words over 600 watt hours of capacity on up to 700-800 watt hours , so that you do not use most of your battery capacity , so that you can get better/longer life from your battery pack .
it is Best to buy a Battery Pack from an known and trusted vender , like Grin Technologies just north of you , there in Vancouver B.C. or em3ev.com
or Luna Cycles LLC. , Luna seems to have the best selection and reasonable prices right now.
Em3ev.com and Luna Cycles LLC, if you want to do the conversion yourself,
or
Grin Technologies, if you want a close by , excellent , vendor that can hook you up with everything you need, and has allot of experience with your needs.
Buying Local is always better in the Long Run, especially when you have such a great business ( Grin Technologies ) just up the highway from you, there in B.C.
dogman dan said:
For a hub motor. Get a rear geared 500w rated hub motor. Not a direct drive. Geared motor means an internal planetary gear system allows it to freewheel normally, while a direct drive motor will resist slightly when you pedal motor off. The motor rating is 500w,, but for the steep hills you have, you will want to run 48v, which means your actual system power is likely to be at least 1000w
Or do the mid drive, which does shine best on hills. This is because the motor actually uses the bike chain, allowing the motor to have the low gear. A hub motor is essentially stuck in one gear.
Budget,,, double it. sorry. but that's the way it is for a good BBso2 kit or a good geared motor kit and a reliable battery that is not shipped illegally.
Didn't say 800 bucks is impossible, just hard to do and meet your particular criteria. Cheap DD kit from amazon, and a cheap battery is what many folks would put on a steel MTB. Then they would ride it with the power on at all times.
https://www.amazon.com/Lithium-Battery-Discharge-Electric-Lockable/dp/B01K3UPUQU/ref=sr_1_7?ie=UTF8&qid=1473079060&sr=8-7&keywords=36v+10+ah+battery
200 buck battery on amazon? hmm. here is one.
How can that thing ship from the USA at that price? How can it ship that fast from China without an illegal flight?
Specs are interesting for that one. is it 10000 mha (10 ah) or 2850 mah?
rosemaryflowers said:
I've got a chromoly frame Specialized Rockhopper I want to convert and am looking for some advice. I'm just learning about e-bikes - been reading this forum for a couple hours and still working through the wiki, so my baseline level of knowledge is still beginner.
I live in Seattle and have been wanting to go e-bike because of the hills. I love to ride but hate the hills. And I live on a hill with 21% grade, though I can avoid that one, there's still probably ~10-15% grade around me I can't avoid. I have no speed requirements - just looking for an affordable set-up that helps me up the hills. I imagine the longest distance I'd ride round-trip would be ~ 40 miles, but only using the assist for maybe 1/4 of that. I don't plan on hauling much, perhaps some light groceries in panniers. I am 5'6, 150 lbs. I plan on upgrading to disc brakes. My wheels are 26".
My budget is preferably $800 or less.
Any advice to get me started? HUGE thanks!
