cbr shadow
So I've been working on my etrike, planning what to buy, planning how to come up w/ extra cash to afford exactly what i want, and recently putting everything together. I have a KMX Trike, HS3540 motor, Lyen 18FET controller, and 24s lipo. I needed 1 last bullet connector for my build, so I drove the etrike to my fathers house where I knew he had some 4mm bullets. Connected everything and took off! Huge grin ear to ear the entire time. I probably got up to 40mph on a straight/downhill, and it took my up a steep hill (probably 12 percent <guess> grade for 1/8 mile). Nothing too insane but with just pedalling it's a difficult hill. These were the only roads nearby so I went around the block once (1 time up the hill) and back to my parents house once, then let my father take it around the block, then 5 min later I took it 1 more time.I kept checking the hub motor and it was warm but not "hot".
I was about to load the trike back into my car when i decided I'd take it one more time around the block. I went around the block and was already up the big hill and headed down a long straight when the power just cut out. I let off the throttle completely, then gave it a little more gas and it lurched forward but wouldn't go. Then I hit the kill switch, let it sit for 30 seconds, then tried again but this time no movement at all. The CA still got power, just no movement of the motor.
I haven't set any program on my cycle analyst, just plugged it in and started riding.. is it possible that the CA cut it off? I had the batteries balance charged to 4.1v to begin with, but they were of course dropping quickly while I rode around.
So my question is.. What are the obvious things to check first? I realize I was a bit hard on it to begin with by going up hills like that at full throttle without pedaling much, but I honestly thought it could handle way more than what I was putting it through. Thoughts? Where to start first?
Thanks,
Ryan
Thanks,
Ryan
