Newbie first build
I have been reading for a week and have some questions. I want to build a ebike to ride drive in California. It can be 1500w max with no peddles max speed is 30 mph. It is going to be a 2 seater with 3 wheels. My commute is 8 to 10 miles. The bike with riders should weigh in at about 400lbs max
I found a 1500w BMC brushless motor http://www.thesuperkids.com/15wabmcbrmos.html
Motor is 3800rpm @36v and 4900rpm @48v I do not have the torque. I will call on Monday to get the torque.
They also have a kit the 1500w BMC motor and a 72v 55a Crystalyte controller
1.Will I get better performance out of a Kelly controller like the
KBL72101,24-72V,100A,BLDC Controller/With Regen
2. Is anyone on the forum using this motor? http://www.endless-sphere.com/forums/viewtopic.php?f=28&t=22560&p=368442&hilit=motoped#p368442
This post looks like the same motor with custom winding.
3. What would be the advantage disadvantage between the Kelly and the Crystalyte controllers?
4. How do I calculate the gearing to get the bike to top speed?
5. How do I calculate battery size?
16s 36V 16Ah LiFePO4 Battery Pack
6. Is 16s 20s is this to do with the BMS?
7. Is ah amp hours?
8. Will a higher ah give you more distance?
9. Higher voltage will have more speed will it give you less torque?
With these simple questions I hope I can stop asking so many questions.
7. Is ah amp hours?
