Skedgy Sky
Update: Go down to 4th post, as I've decided to rewind it.
This motor failed while it was cold probably when two connectors came in contact with one another (this was months ago).
Today I decided to attempt to rewind it and so I was cutting away at the windings (did some labeling, mainly one phase as the other two were shorted and would have proved to be difficult); this is my first motor rewind, by the way.
After cutting up part of the first yellow phase, I decided to see if I could locate the short between the blue and green phase.
I kept my multimeter testing for continuity between the blue and green phases (as they are shorted together. Note:the wye is seperated
I got down to the last strand of wires.... and just out of curiousity decided to cut the charred wire from the strand which resulted in loss of continuity between the green and blue phase (somewhere along this wire must have been where it was short-circuiting the green and blue phase!).
Granted, this was the last set of wires I got down too but the charred wire must have meant something...
Now I'm not sure which route I should go with:
Do I continue on removing the windings and rewind the whole motor or do I reconnect all the connections I broke and hope this charred wire was the cause of the death of the motor?
I've circled in red the area in question.
http://i.imgur.com/mYo1oSS.jpg
