John in CR
100 TW
After seeing Leboski's post that stator oriented control was more efficient for regen braking, I started wondering how much difference it would make. Then on my latest build on the first test ride only one controller was running the 6 phase motor. While everything was fine running nice and smooth under power albeit at half the torque, when I engaged regen having only 12 stator teeth working on the 10 pole pair motor it was rough and noisy during regen braking. It was very similar to the plug braking of a blown controller with 1 phase having shorted mosfets.
With 2 controllers running regen is smooth and silent, except maybe a hint of noise and roughness at the end of the final rotation before coming to a full stop using regen. The huge difference during forward power and regen braking with only one controller tells me that the difference of SOC during braking could be big, so my questions are:
1. How much more efficient could regen energy recovery be...both from a range extension and a heat generation standpoint?
2. With a controller that has FOC control, how hard would it be to implement SOC for braking?
