JDELUNA
Now this is something pretty interesting !!! Enjoy and God Bless
http://news.en.autos.sympatico.msn.ca/article.aspx?cp-documentid=5044057
TylerDurden said:Ever tried filling a single car-tire with a hand pump? Takes about an hour. That much air couldn't even budge the lightest of cars.
If the car's engine were running on air, running a compressor too, would be like Wiley Coyote blowing into the sail of a wind powered car.
If the engine were running on gas, why bother with air?
Sure it is. Try a simple experiment. Run the TDI for 15 minutes. Then fry an egg on it. With an electric motor properly sized to the task, your egg will remain runny. Heat (from an engine) is waste. Inefficient, unless you like your eggs well done.It's pretty hard to beat the new TDI diesels.
Lock said:Sure it is. Try a simple experiment. Run the TDI for 15 minutes. Then fry an egg on it. With an electric motor properly sized to the task, your egg will remain runny. Heat (from an engine) is waste. Inefficient, unless you like your eggs well done.It's pretty hard to beat the new TDI diesels.
tks
Lock
fechter said:What it you compressed hydrogen or natural gas, then run that through the air motor. The low pressure "exhaust" could then go into a fuel cell or ICE to get even more power.
xyster said:Though the air is essentially free, it takes just as much, if not more, energy from such sources to compress that air. The major energy corporations have nothing to worry about so long as they can adapt to the changing energy landscape.
