Hi Folks - I have a Freego Hawk 36v ebike. I tried to increase the power by adding some solder on the shunt in the controller. Since then, I'll travel about a mile then power to the motor cuts out, although all the led lights are still on. After 10 minutes or so power seems to be restored and I can continue my journey. This happens often. It seems to me that some type of thermal cut-out is operating. I'm a novice at these things and perhaps shouldn't have messed with the controller in the first place. But I did get advice from so-called experts and they said that some extra solder on the shunt wouldn't do any harm and would increase the power to some degree.
I've also read recently that charging your battery in cold weather (in an outside shed) can cause this. Is this just a red herring, or is it a thermal cut-out as I suspect?
Thanks in advance for any answers that are easy to understand - as I said, I'm a novice and not very technical with electronics.
