MitchJi
Hi,
I think the best solution would be to modify Surly 13t cogs to fit on White FW's using an adaptor. I bet Jason would make some adapters and modify some cogs for under $20 per set. That would be the the strongest FW with a strong 13t sprocket. I'm not sure if it would be easier to modify cassette cogs or track cogs. I think I'd use track cogs because they are available with 1/8" tooth thicknesses.
Track cog:
http://www.treefortbikes.com/121_333222337776__Track-Cog-1-8-13-16-Tooth.html
Cassette Cog:
http://www.treefortbikes.com/91_333222338203__Single-Speed-Cassette-Cog.html
Miles said:recumpence said:One thing I am kind of green on is, I know there are two thread sizes (diameters) on BMX hubs. I know the larger side is the most common. Is the larger thread what we are looking for? Is the smallest tooth count freewheel for our purposes 11 tooth?
11t? You used to be able to get 12t freewheels for the BMX metric thread but I think the smallest now is the Odyssey 13t.
The smallest freewheel for ISO standard thread is the AC Racing 15t.
One thing to bear in mind is that BMX has mostly gone over to cassette now, so we don't know for how much longer the smaller thread freewheels will be readily available. Anyway, at the moment, the Odyssey is a good choice - it's available LHD, too.
Track cog:
Like our cassette-splined cogs, these are made from machined, heat-treated and chrome plated SCM415 CroMoly steel, so they are tough and long lasting. Track cogs are available in either 3/32" or 1/8" tooth thicknesses and in every size from 13-22t.
Cassette Cog:
Our cogs will work with 6-9-speed 3/32" chains, although we recommend the inherently updated quality of an 8 or 9 speed chain. They are also available in every increment from 13-22t, so you can select that perfect gear.
