recumpence
1 GW
You probably got the last set of 170mm black cranks didn't you? I had to settle for silver. :wink:
Matt
Matt
recumpence said:You probably got the last set of 170mm black cranks didn't you? I had to settle for silver. :wink:
Matt
D,deecanio said:i posted that forum thread as a fairamount of ppl have had the echo crank freewheel threads strip???
i was suggesting another brand?
deecanio said:so were the stripping ones in the thread a different grade of ally? meh you guys know what your doing.
D
deecanio said:Miles, if i used the Hacker and could get away with single stage do you think i could use belt to connect from gb output to crank?
deecanio said:thansk Miles,
maybe i'll have a nosey around seems like there's quite a few to choose from, i do like those blue ones though, nice.
a feck it maybe i'll swap to ISIS so i can have the blue, we'll see.
I am also considering going with Gary's hacker too (which model is it Gary?) - conditions being it can handle 5kw and its as well supported as the pletty? reason being i would like to use single stage reduction and the hacker has a kv of 148 i believe, we'll see.
Cheers,
D
deecanio said:i could do 6-1 at the box 8-1 at the crank?
