John in CR
100 TW
I finally decided how to put my 2 wheelchair motors to good use. I also have 2 EV Warrior friction drives that have some kind of one way freewheel bearing. I need to fabricate a 3.4" diameter friction wheel that will get me right at 10mph per 1000rpm.
Here's the twist: I'll slide both EV Warrior friction wheels into the new larger friction wheel. This will give me the ability to use either or both motors at the same time. If one is idle, it's shaft will freewheel inside the bearing. This should give me plenty of hill climbing torque and acceleration, along with good cruising efficiency in a weight balanced drivetrain that is easy to transfer to any bike. While the extra motor does add an extra 7lbs and I will need 2 controllers and throttles, I think it will give me a very reliable and quiet rig with plenty of oomph.
I don't have a clue as to how much friction drive tension to use, so I want to make that easily adjustable. Then I can run it at the lowest friction I can without slippage, and tighten it up if necessary for the conditions (wet roads, etc.). Also, I believe that being able to alternate which 24v motor is in use that I'll be able to over-volt them to 36v without concern about durability.
From what I've been able to find through searches here in the forum, I'm surprised friction drives aren't more common. The typical issues brought up regarding tire wear and slippage when wet are contrary to what is said by those who have used friction drives for years. Instead it seems to be an efficient and quiet drive system. I love the simplicity and lack of chains and gears. If I make the drive wheel removable and make a few different diameters, then I can even easily test different gearing ratios.
This will be a test bed for a dual RC motor rig using a similar easy setup with cheap lightweight yet powerful motors. I think the larger diameter drive wheel will be a benefit. I know friction drive is old school, but if anyone sees anything that I'm not considering, I'm all ears.
John
John
