adrian_sm
RayB said:The throttle is a roller dial. Basically mount it under your bar and roll if with your index finger. First one I've come across that I can use easily on the drop bars.
Is it sprung loaded to return to zero throttle? I found mine annoying with no spring return as I would forget to turn it off when braking.
Kepler said:The adjustment seems to be an end stop when under power and I think you adjust the drive postion so its in contact with the wheel all the time even when not under power. I think the idea is to keep the contact light and have the one way bearing free wheel when not under power. Thats what it looks like to me anyway![]()
I agree no point in the one way bearing otherwise.
