DeadEyeDave
10 µW
- Joined
- Dec 18, 2013
- Messages
- 5
Hey all! I have haunted this forum for a while with dreams of adding an electric motor to my bike. You all are very knowledgable, moreso than I will ever be. And so, I come to thee with some questions. Let me explain my plans and then I will ask you the questions that are on my mind.
I have a Trek Navigator 400. http://www.trekbikes.com/us/en/bikes/2003/archive/trek/navigator400/
My plan is to put a hub motor on the front wheel. There is a thread on here with a guy who had the same bike as me asking about putting a motor on the front, http://endless-sphere.com/forums/viewtopic.php?f=3&t=48291&p=710801&hilit=trek+navigator#p710801
It is an aluminum frame with aluminum forks on the front. I know that some people said that it is a bad idea to put the motor on that. I would be using torque arms and everything to hopefully make it safer. Now my reasoning behind putting a motor on the front instead of the back is because I plan on putting an 80cc IC motor on the back. I want to put the electric on the front for low end torque and stealth while riding through residential areas. I go to work at 4:45 in the morning and my neighbors would shoot me if I ran a two stroke by their homes.
I want to buy some sort of front hub motor kit. An all in kit with everything included. I don't want to buy parts and pieces and have to wire batteries together and figure out how to charge and balance and maintain them, and worry about my place burning down if I do something wrong.
So, I'm looking for a kit, I think 350-500 watts. My daily ride to work is about 5 miles each way with no BIG hills, but there are hills along the way that I will need to go up. Is there some kind of kit that includes everything, sorta plug and play? stick on a new wheel with hub, strap the controller battery and throttle on the bike and go? Like I said, I'm looking for a simple battery setup. Something that I can plug in at night and not worry about untill I unplug the charger and go to work.
So does such a kit exist? I'm looking to spend up to 1000, but if I'm being honest, I will be happier spending less.
I'm comfortable with a wrench, I do believe that I can install a system onto the bike, but the battery forums really freak me out. you guys are on another level with the battery stuff and I have to admit that is what scares me the most. If there is a system that is akin to charging a power tool battery, I would feel so much more comfortable.
Thanks for any help you guys can give. I've have fun over the past few months reading through this forum and checking out the amazing bikes that you all put together.
Dave
Dave
