So, i have recently ran in to this kind of problem - my alibaba stealth bomber clone started to lean to the right side, wich made riding extreemly uncomfortable. So i ordered new seat mount, rear swing arm, as i checked almost all other options ( rear wheel alignment, headset tighten etc). But now i found out my front wheel is off center around 1cm to the right. I see why is that (l will add photo) - the side with a brake disc has a larger spacer and wheel is cetered considering spoke holes and not the hub overall (i have replaced the original hub, but the one that came with the bike has same built) My question is - how do i fix it? The only solution i can think off is tightening spokes on the side of the brake disc and loostening them on the other. Please help
