[FS - Burnaby BC or Seattle WA] Like-new ZAC 19 700c + Grin Shengyi SX2 rear, 7sp cassette installed, ridden 1x - $379 CAD OBO
NaCly
🧲 New user
Vancouver, BC, Canada
Built but only ridden once (didn't like the , essentially like new. Moving on to motorcycles.
Rim:
  • Weinmann ZAC 19, 700c, 36h, double-wall
  • Tubeless tape: not installed
Motor:
  • Grin-spec'd Shengyi SX2 rear geared hub
  • Standard 8T, 7.4 RPM/V wind (the 26"/700c variant)
  • 250-500W nominal per Grin's honest rating; capable of higher with thermistor rollback
  • Helical-cut single-stage planetary, very quiet
  • Built-in clutch, no drag freewheeling
  • Combined speed + thermistor sensor, Z910 9-pin waterproof connector, 22cm pigtail
  • O-ring sealed side plates
  • HG cassette freehub (9/10/11sp compatible)
  • 6-bolt rotor mount
  • 135mm OLD
Cassette:
  • 7-speed installed with 4.5mm spacer behind it (standard practice for HG body)
  • Body will accept any 8/9/10/11sp HG cassette if you want to upgrade
Compatibility notes:
  • Shengyi hall mapping is non-standard. Pairs cleanly with Grin Baserunner_Z9 (programmable hall mapping) or any Phaserunner. Will need hall remapping for a generic Bafang/KT/JBK controller. Don't buy this if you're plug-and-playing with a generic controller from AliExpress.
  • Z910 connector is the Grin/Higo standard; almost every Grin controller uses it natively.
Not included: Controller, battery, display, throttle, rotor, tire, tube.
Logistics:
  • Local pickup preferred, Burnaby BC or Seattle WA with a heads up.
  • Ships easily, ~$30-50 in Canada
  • Cash, e-transfer, zelle, crypto, or PayPal G&S (buyer covers fees)
Asking $379 CAD OBO. Pricing flexible.
WhatsApp Image 2026-05-03 at 17.56.34 (20).jpegWhatsApp Image 2026-05-03 at 17.56.34 (23).jpegWhatsApp Image 2026-05-03 at 17.56.34 (22).jpegWhatsApp Image 2026-05-03 at 17.56.34 (21).jpeg
