orcasmarx@yahoo.com
10 µW
Iwhenever I hook up my throttle in pass through mode to the CAv3 full throttle only goes to 1.5v. When I hook the throttle directly to the controller I get normal voltages (.86v in 3.76out). I have been talking to Justin at Grin Tech directly but I was wondering if the members could be having the same problem.
Everything is normal if I run the throttle in pas thru mode if I unplug the motor. I have cheched and rechecked all the perameters.. I have set the min thro in to 1.0 and the max out to 3.76 ( reading from the CA diagnostics screen). Temp sensor, PAS, all disabled. I programmed in the Battery, 57.8 volts, Amps 50 (controller specs), shunt 1.4 (controller specs). All the rest of the parameters are default (physically verified). The controller is a Edge 3000 50a, And came with a CA plug. I have tried to get information about the controller from the seller to no avail. Lastly, I want the give praises to Grin Tech's high level of professionalism. All my emails and questions have been responded to. I would appreciate ANY HELP on this.
