dogman dan
1 PW
This is the new 48v version of the Fusin motor kits sold by World Wide Electric Bikes. This was supplied to me directly by Louis at Fusin Motors, and as yet, I don't know if any dealer in the USA is carrying them.
Several improvements were made to the kit, compared to the 36v version I tested and reviewed last year. No pics at the moment, but I'll get some up soon. I will also edit and expand the first few posts as data accumulates.
The biggest change was that the motor does not freewheel. This means the Fusin kit controllers REGEN BRAKING can be used with a gearmotor. Far as I've heard, the only non freeweeling gearmotor.
The other changes were lowering the amp limit to 15 amps, vs 20 amps on the previous kit, shortening the wire between the battery and the controller by about 6 feet, and a different arrangemet of the throttle and three way switch. All the changes made sense to me, even the lowering of the amp limit. The motor provides the basic commuters needs just fine at 15 amps, while the lower limit will extend the battery range and most likely the cycle lifespan.
The previous kit had a key switch on the headlamp that carried the full voltage, making it required to have the battery wire go the length of the bike and back. Now the key still turns on and off the controller, but the motor power does not go to the headlight. Only the power to run the light goes to the handlebars, and the battery wire goes directly to the controller.
The previous kit had the three way switch on the throttle, It has been moved to the other side of the handlebars, and now is part of the horn button and light switch. This allows a throttle replacement with a standard commonly avaliable throttle if it should get broken. The three way switch enables three modes for the controller, a low speed mode that climbs a steep hill a bit better, a medium speed, and a high speed that works best on open road with no stops. As with the 36v kit, I find the mid speed provided the best performance in stop and go traveling, and climbing hills up to 5 or 6% grade. Each "speed" or "gear" has a different wattage at full cruising speed, so an easy way to economize watts is to simply select the slower speeds when more range is needed. The lowest speed is great for slow cruising on boarwalks, or walking the dog on dirt roads. The mid speed is perfect in city riding with a dang stop sign every block, and the fast speed ideal for eating up miles on the open road.
