The internet repeatedly established weight of a single Twin Tower is 500,000 Tons.
DL(110) = 500,000 Tons
The weight of the 16 Floor alleged falling block is much less than 73,000 Tons, as the steel is only .25 inches thick at the top, but we will consider the whole Tower to be of uniform thickness.
DL(16) = 73,000 Tons or less
The weight of the lower WTC 94 floor block is 430,000 Tons or more as the steel gets progressively thicker and thicker,until it reaches 4 inches thick toward the bottom floors.
The top alleged falling 16 floor block is less than (1/6) the weight of the lower 94 block.
Even though the top block was very massive, on a comparitive scale to the lower 94 floor steel, highly intact block, according to the laws of Physics, it could never collapse the topmost 94th floor, floor 94, with its gravity weight of force alone, much less the entire 94 floor steel tower below.
The Tower could support 20 times its Live Load (LL)weight.
CL = Collapse Load
CL(94) = 20 x LL(94) (via John Skilling, WTC Cheif Enginer, deceased, but published everywhere)
The Live Load is confirmed by NIST 911 Commision Report Science Guy, Ronald Hamburger to be:
LL(94) = 5 x DL(94)
therefore:
and therefore:
CL(94) = 20 x (5 x DL(94))
and therefore:
CL(94) = 100 DL(94)
According to the above, the very unique Safety Factor is the Collapse Load Factor, whis is:
100 x DL(110)
It is not 5 DL(110)
It is not 20 DL(110)
It is 100 DL(110)
& it is 20 x 5 x DL(110)
Get over it OCT misguided dupes and misguided PHDs.
This means the the lower 94 block of steel could support 100 blocks of 94 floors before possible total collapse could occur.
This also means that the lower 94 block of steel could support 588 blocks of 16 floors before possible total collapse could occur, since one 94 block is equal to 5.88 16 floor blocks.
588 Vector Force units of upward support (stressed Normal Force)against 1 Vector force unit of downward gravity weight force, all by its lonesome.
Now apply Vector math Addition to opposing Forces to find that the top block could never in one's wildest dreams totally collapse the lower 94 floor block of powerfully strong and very thick,
4 inches, steel.
588 Force units of upward support
minus
1 force unit of downward weight Force
gives 587 force units of non-collapsing support.
1 Force Unit(FU) = 1 DL(16)
(588 FU up) - (1 FU down) = 587 FU up.
No collapse can possibly occur...
CL(94) = 588 DL(16)
That is crushing and most devastating news for the Original Conspiracy Theorists in the Government and in the Mass Media.
They no longer have a lying and deceitful or ignorant leg to stand on.
Amen, story over using Vector Forces Physics. the Ultimate Truth and Proof.
That is the Final & Ultimate answer as to why the twin towers could never, ever collapse under the conditions offered by NIST, the Government, the Mass Media, and the big name University and corporate PHDs.
Since the confirmed discovery of the red and gray nano Thermite active and explosive particles in the WTC dust samples, there is no leg to stand on by the NIST, government and all the "quack" PHDs hired by the Government to do their lying diry work with the Mass Media.
Game over. Get the Gallows and Guillotines ready!!
Here is a little bit of shocking information for you OCT people and non physicists to digest.
You would have to raise the top 16 floor block, the alleged falling block, to a height of 120 miles above the 94 floor block and then drop it. The 16 floor block would drop for 200 seconds and collide with the top of the lower 94 block at a velocity of 4,500 miles per hour with a colliding energy of 1.5 x 10^14 Joules of energy before total collapse could occur.
That collision energy, 1.5 x 10^14 Joules, is the energy equivalent of 2.4 Hiroshima Atomic bombs or the equivatlent energy of 36,000Tons of TNT or a very large number of mini nuclear devices.
This is attained only if there is no air resistance, in ideal conditions of Free Fall. Because there is air resistance, the Terminal velocity of about 1200 miles per hour will prevent the top 16 floor block from attaining the required collision velocity and the required collision energy to totally collapse the botton 94 floor steel tower.
In other work, under any conditions it will be impossible to totally collapse the lower 94 floor tower.
Amen....End of the Official Conspiracy Unscientific Theory of NIST, the Government, the Mass Media and the retarded PHDs from the Universities and Industry.
All of those PHDs are shot down in flames, becoming the laughing stock of their students and peers. They all need to retire and spend the money they got for writing and supporting tnose stupin and foolish ideas and theories they have corruptly put forward. Their careers are doomed.
Chuck Boldwyn
Retired Physics & Chemistry Instructor.
cboldwyn@bellsouth
You may request my detailed PDF research report to be emailed to you if you send me your email address at cboldwyn@bellsouth.net.
You will be amaze and shocked when evaluating my blockbuster research findings.
Bring on the debunkers, if they are brave and foolish enough to try their foolish best...
