cwah
Hello there,
I've been on Ebike-kit site, and I've seen there table comparison between geared hub and direct drive:
350w Internally Geared Motor
Advantages vs. Direct-Drive:
Lighter Weight (7 pounds vs. 14 pounds)
Smaller (134mm diameter vs. 244mm diameter)
Zero Drag (complete freewheel when not using battery)
Excellent Efficiency (15-25% more range)
Disadvantages vs. Direct-Drive:
Lower Top Speed 36v (17.5 MPH) / 48v (24 MPH)
Less Power (350w vs. 500w = 40% hill-climbing power)
Moderate Life span (internally geared parts wear down. 2+yrs expected)
*Internal gears are replaceable by E-BikeKit
500w Direct-Drive Motor
Advantages vs. Geared:
High Top Speed 36v (20 MPH) / 48v (28 MPH)
More Power (500w vs. 350w = 65% hill-climbing power)
Excellent Life span (brushless and no friction = "last forever" 5+yrs expected)
Disadvantages vs. Geared:
Heavier Weight (14 pounds vs. 7 pounds)
Larger (244mm diameter vs. 134mm diameter)
Slight Magnetic Drag (slight resistance when not using battery)
Moderate Efficiency (15-25% less range)
http://e-bikekit.com/electric-bike-conversion-kit-motor-for-bike-e-bikekit.html
Direct drive would have 15 to 25% less range under the same condition? that's huge.
Do you have the same result from Direct drive hub?
