cheapcookie
- Joined
- Aug 2, 2014
- Messages
- 277
Dear endless sphere, I need a cargo van(think ford E350 or E150) moving at speeds of around 10mph on electric power for less than two miles
(range doesn't matter much here, correct me if i am wrong, it would only need to do two miles twice a week)
weight is around two tons with the combustion motor!
or a reduction of 20:1 is the enough reduction to get the van to speeds?
weight is around two tons with the combustion motor!!!!
Am I missing out ? I would love to be at the same not wrong and not right! I have so much to learn!
Let's say my wheels are 16in(40cm) in dia, it would require 300rpm to go 20km/h(12mph)There's a few ways I can approach the problem in my mind. (excuse my ignorance, I literally know nothing about cars, and large EV)
I can use a car conversion kit, motor adapter, big motor. (out of my budget and or out of my garage mechanic skills)
I can make a 5th wheel, or power the drive shaft with a large reduction, direct drive power the wheels.
I can use a DIY version of this externally![]()
I want to use a +10Kw motor such as the ETEK or a big rc motor or ebike motor or multiple rc motors.
my requirements, are :
integrated inside the van
I do not mind removing the combustion engine because of weight and space saving.
I do not mind keeping the combustion motor for extra redundancy, but it would most likely go.
any speed, happy with 5mph if its an easy conversion, very very happy with 20mph
it has to be easy and cheap and quick(all contradict each other, but hey yolo)
relevant link to pictured E-TUG http://www.canev.com/might_e_tug.php
