SoMoney
- Joined
- Dec 6, 2010
- Messages
- 30
The BIKE: 2001 Giant NRS XTC1 Aluminum FS Frame (MTB of the Year). ($1200-$700)
The Kit: E-BikeKit.com Electric Bike Conversion Kit - REAR - Direct-Drive ($392.00)
The Battery: 4 x 6S1P Turnigy 5000maH 25C-35C 22.2V Packs Wired into a 12S2P 44.4V 10AH Brick configuration. ($256.50)
UPDATE: REPLACED CONTROLLER WITH 12 x 4110 MOSFET Extreme Modder Controller LYEN Edition! ($129)
UPDATE: Added a SHORT FRAME BAG FROM HI-POWERCYCLES.
===================================The Build SO FAR====================
Since I'm Running 4 x 5000maH in a 44.4v 10AH Configuration its Quiet Small.. I'm Toying Arround wiith the idea of forging the rear rack and getting an under seat bag that can accommodate.
The DISC required 2 extra washers to line up with the Avid break pads.. Its still a smidgen to short but I'll probably run it until my next pad replacement.
I'm Using Velcro straps right now so I can adjust at will.
This is the part that Scares me with these eBike builds on Aluminum frames....... Necessary but a hose clamp? Really?
TOTAL WEIGHT WITH 10AH 44.4V 12S2P Turnigy Packs: 50.0lbs
TOTAL WEIGHT WITH 10AH 55.5V 15S2P Turnigy Packs: 53.0lbs
