briangv99
Hi,
here is my build. The key bits and pieces I'm currently using are -
Giant Yukon FX
Kollmorgen 400w 24v with planetary gearbox with 19t output
Vision Independent Pedalling Sytem modified to take White Industries Eno
90t #25 sprocket
Shimano Alfine
Esge twin leg stand
Various bits of alumium cut and hammered into shape and u-bolts welded to a bracket for the motor/stand mount
Performance with the current setup at 24v setup has been quite good, though pushing the motor continously at 1000w for extended periods seems to have taken its toll on the controller. I'm in the process of building an r/c drive system running at 36 or 48 volts, hoping it will give the bike some much needed grunt, though it will climb the steppest hills offroad with some assist as it is.
Giant Yukon FX
90t #25 sprocket
Shimano Alfine
Esge twin leg stand
