GiantEV
I got tired of the Crystalyte HS3548 motor overheating (rated at 1200W and I was pushing 4000W through it) so I decided to switch to the MXUS 3000 v2. I took it for a test ride today. The MXUS has way more torque using the same batteries and controller (Mini-E). Also, the MXUS doesn't overheat like the HS3548 did.
My top speed is also a little higher, which is strange because the MXUS has a lower KV. This might be because I have a good tune on the Adaptto for the MXUS and I don't know if the HS3548 was ever tuned with optimal settings. The HS3548 has a KV of 13 (from the ebikes.ca website). The MXUS is a 3Tx21 motor, which is listed as 12 KV in this thread: http://endless-sphere.com/forums/viewtopic.php?f=2&t=63142&start=800#p989453
I'm very happy with this motor. With a 20" wheel I'm getting around 45mph consistently(48mph max but it may have been a slight downward slope). I ran 10a Turnigy wires to the motor, but the last 6 inches or so of wire going into the motor is the original wire, which looks to be around 12ga.
Here are the two motors side-by-side:
