There are two ways to help prevent the "auto regen".
One is to use a higher battery voltage, one that is *always* above the generated voltage, even when it is empty. That's the simplest option. Since the *runner series is a current-control throttle, then it will still behave about the same. (vs a speed-control throttle where it would be more difficult to control at a higher voltage for small throttle amounts).
Another is to use a different wheel size, though this is not as practical; it has to be proportionally different enough to avoid generating that higher voltage.
You *might* be able to use Field Weakening setup for that high a speed to actively drive the motor during the downhill, but this will make you go even faster and at some point you'll go faster than the system can deal with, as the voltage generated would be higher than the controller FETs/etc can handle, and they'll fail.
Which brings up another situation with downhill regen: If you start out with a battery near or at full charge, the regen will continue to charge the battery until the BMS deactivates it to protect it from overcharge, disconnecting the battery from the controller.
If the BMS is a common-port type, that will mean the controller has nowhere to dump this current now, and it becomes a voltage that builds up (not like static electricity) very fast and can quickly exceed the voltage the controller FETs and other parts can handle, destroying them.
If the BMS is a separate-port type, then it can't stop the regen current, and the cells will begin overcharging. How serious this problem is depends on the length of time the regen goes on, and the amount of current flow there is. If it's a very low current, less than 50mA, it's likely that the BMS balancing shunts (if it is a balancing type) will handle it. Above that (whatever the shunts can do) the cells will charge.
As long as the battery is never near full, there's no worry. But if you live at the top of a hill and start at a full charge...that can be a problem. :/
