GNG Cyclone 3000W Kit @ 72V?
chiBikeE
New here
Hi,
I am looking into purchasing the cyclone 3000w kit from GNGeBike since they have a pretty strong bracket that holds up the motor. It is also like the only place that has it in stock right now.
https://www.gngebike.com/gng-2019-3000w
I already have a 72V (20s 16Ah) battery pack that I'm planning to use in it, but the website says the controller that comes with it only supports 48V-60V even though the controller in one of the pics says 48V-72V. My question is will the controller support 72V?
Also has anyone ordered from them before? How long do they usually take to ship to USA?
Thanks.
More then likely, but it all depends on the capacitors inside the controller.
I am using a 36v controller with 52v battery because the controller has 60v capacitors and the battery fully charged is 58.8v (14s).
Most controllers 48v+ have higher voltage capacitors, 100v maybe?
My 52v 14s battery has a bms for lvc so its safe to do it in my case.
I bought this one and can confirm the bracket and construction is top notch. You might want to buy the bracket from them and motor & 72v controller from cyclone tw direct.
