iperov said:Got GNG2,
some problems with installation of chain tensioner.... so currently motor without tensioner
Isn't the whole unit built on a BB framework, automatically aligned? What was the issue with the tensioner, photos?tomschmidtty said:iperov said:Got GNG2,
I also installed 36V/350W GNG Gen2 mid-drive without the tensioner. It is tight enough for now.
This was a challenging kit for a newbie like me to jump into as my first e-bike, so I imagine most ppl on this forum won't make the stupid mistakes I made.
Basically, BB/motor alignment is tricky; and with zero installation directions included, there are plenty of teaching moments to be had.
This sounds like another GNG manufacturing issue. Surely the original design didn't make this clearance error. Crank arm flex is to be expected. I'm not sure I understand about the damage to "the thread of the aluminum arm where it threaded into crank." Did you get any photos of this? Are your repairs/modifications holding up. Best wishes and cheers!tomschmidtty said:My alignment issue was due to the position of their crank chain-ring being so close to one of the nut/bolts connecting the motor to the BB assembly.
The freewheel crank spun fine while installing, but I think my weight/force while pedaling uphill was enough to wiggle the drive a few millimeters. This jammed the crank, stalled the motor, and then I pedaled thru the jam (which destroyed the thread of the aluminum arm where it threaded into crank).
Yesterday I put on a stronger chain on motor sprocket, filed down the nut/bolt a few millimeters with a grinder, and fixed (hopefully) the arm/crank thread connection using JB-Weld Epoxy. pics show the circle of scratches that the nut left on the chain ring
iperov said:GNG2 and ktrak
46V 36A
[youtube]M-ZB87Ky-10[/youtube]
no its ktrak skipping.rodgah said:iperov said:GNG2 and ktrak
46V 36A
in this video near the end it sounds like the chain is skipping? is it the ktrak or drive chain or simply the front ski on the ground?
I would love to see a video of it on a harder surface to imitate what it would be like with wheels and no snow. maybe rear facing camera showing you go through the gears like your other video. Does the motor or the controller get hot running on ~1600watts (46v 36a), and is that the stock controller or have you soldered its shunt?
cheers
Rodger
Are you running with 48v. I run mine at 36v and 22 amps and the power/torque characteristics seem to be about right for the cadence; however, I could do with a bit more power for the hills.jpo said:I received and installed a gng gen2 kit a couple days ago.
Early impressions and qualifying statement.
First off I my focus is not high speed and power. I want a bike to go normal to fast bike speed (tops maybe 25 mph), climb hills and carry modest sized loads up those hills and into headwinds. I typically ride another bike with a rustic homemade version of the stokemonkey. I really like the way the original stokemonkey worked but I wanted it to freewheel. So I made one myself.
The gng gen 2 has plenty of power for my riding. It will get me up steep hills and i am comfortable with the top speeds.
The cadence speed is about right but the torque comes on a little strong. It would be nice if the torque could ramp up slowly and peek somewhere around 80. instead it has a lot of torque off the line and tapers off. as it reaches peak.
The quality of construction is low. I would say crap but it does works. The question is how long will it last for. Nothing is quite right. Crank freewheel out of round causing tight spot in chain(but they always are). Idler pulley low quality and easily damaged. Main mount to bottom bracket not exactly square. And like tomschimitty I had to grind down one of the nuts to allow clearance between the inner chain ring and the motor mount bolt. There are no ebrake cutouts included and it does not have an on/off switch. If you get one of these system at minimum add a kill switch for safety or be ready to pull main power supply. Phase wires look to be only 18 gauge. and the metal gears are very loud.
I am hoping the metal gears quiet down after some miles and because I don't plan on running that much juice I may look for replacement composite or nylon gears. that is if it holds up.
More on the positive side. Install is easy and straight forward. They thought the system through and lined everything up ok. I don't have a CA yet but it seems like the stock controller is 20 amp. Way too many amps for 18 gauge wire but it will charge up hills. My rear cog set is 12/34 in the lowest gear it will go up anything you will come across on the road. Depending on your riding style this might even work will on the trail. All in all it a love hate. Love the mid drive performance and low center of gravity but wish the quality was better. That said, the price doesn't demand quality.
Anyone knows where to find quiet cogs to replace the metal ones.
If anyone has any specifics i can answer let me know.
thanks
johnamon said:hi d8veh,
I can see that you've owned a number of different ebike configurations, and perhaps you'd be ideal to answer a couple of questions. I wondered how you rate the Gen2 GNG drive compared to wheel drive systems?
How do you feel about the relative merits? ~I bet it goes up hills well but is your Gen2 faster than a hub motor at the top end, same speed, slower? I like the ability to pull around 30mph, but figure the small motor may not be able to drive at 30mph?
Thanks in advance.
John
Unless you have hills over 20%, you can't beat a 500w geared hub-motor. They're more or less maintenance free and go for thousands of miles with no strain on your transmission. I run all bikes at 36v and the hub-motors are faster up relatively steep hills and I find it easier to ride in economy mode with a hub-motor than a crank-drive. To me, for my riding, the main advantage of the GNGs is their ability to give maximum power at any speed, which is handy for racing our lycra clad friends, where a hub-motor will max out at the speed it's wound for, but you pay for it in reduced range. The GNGs are a bit easier to install than a hub-motor. I think that they would be much more desirable if someone came up with a controller with variable PAS - ideally related to torque.johnamon said:hi d8veh,
Thanks in advance.
John
