Hi, I know it might be a bit late now but I would steer clear of the 190mm BB and get the 1800-3000W with the 148mm BB. I think if you plan on using it on a few jumps it will eventually bend and the chain will drop. The kit will never be perfectly true to begin with so it wouldn't have to bend much to be start dropping the chain under load. My kit is about 1.5mm out of true even with a WI ENO and support bearing and prior to installing the support bearing it would occasionally drop, not to mention flexing under load which will be a function of current/torque something the larger kit will use/generate more that the smaller kit.
I think the 1800W kit represents the best value on the market in terms of bang for buck, without being as noisy as the steel geared kit that I have. The reduction is approximately 6:1 which means it will spin at a lower RPM than the steel kit too so definitely less noise.
Good luck either way, maybe contacting someone from this thread might help.
https://endless-sphere.com/forums/viewtopic.php?f=28&t=69867&p=1054299&hilit=+cyclone+3000W#p1054299
