lexo4632
Hello Everyone.
I have a GM Magic Pie V 5
I have found just 2-3 wiring diagrams for my Conversion Kit, however I can not locate a list or graphic of the wiring color codes, I have of one with the pin outs/ which makes me have to test which color is which, but I would rather not cut up an test wire every single one to figure out what color is which +5v or etc,
the kit is all plug and play wiring except for the PAS and Horn and Lighting
Does anyone have anything on this, I ordered a new Thumb Throttle, for example if I want to wire another non plug an play, the cable for that has switch, LED lighting other wiring for it on that cable.
Anyone have a List of the wiring color codes an what they are
The Wiring is so thin gauge is is crazy, trying to wire a PAS with this thin wire is nuts, or the lighting when I get use to it.
Also anyone have this Kit, know of the bottom on the Thumb Throttle, is it wired to the lighting out cable it has?
