Last year I bought an old Grace One with a dead battery and dead controller.
A Grace dealer said that the price for a new battery and controller is approximitely 1300 euro (!)
For me the reason to modify the Grace One electrical design without modifying the mechanical and esthetical design.
A dead battery (0 volt) and dead controller is very suspicious.
The lack of a BMS in the battery could be the reason for a progressive collapse.
When the controller is leaking current then there is no protection of the battery.
So I think that the controller has destroyed the battery.
Modification: a new battery has a BMS and is located in the old controllerbox.
The original controller has also a switch for the headlights and brakelight.
This part of the controller was brown coloured due to high tempeture.
The controller looks very complicated; it is a combination of functions.
Modification: separation of controller and lightswitches.
The battery has 44 Volt (12s). That is not the standard.
Modification: a new battery gets 48 Volt (13s).
The Grace One has no cruisecontrol en no regen brake.
Modification: add cruisecontrol and regen brake
The Grace One has a dedicated display with RFID key.
The display works tegether with the controller so with a dead controller there is also a useless display.
Modification: standard display, traditional ignition lock and buttons (cruise, speed, light)
The original battery has 4 parts of 44 Volt. The are put together in the controllerbox.
The new battery exists of 4 parts which are connected in serie.
In the upper tube: 8 x 7 = 56 cells
In the seat tube: 6 x 7 = 42 cells
In the old controller tube upper side: 3 x 6 = 18 cells
In the old controller tube dosn side: 2 x 6 + 1 x 2 = 14 cells
Together: 56 + 42 + 18 +14 = 130 cells.
Electrical scheme: 13s 10p
Cell type: Panasonic NCR18650PF (2900mAh)
BMS type: https://nl.aliexpress.com/item/Brand-48v-bms-13S-40A-High-quality-batterie-smart-bms-48v-li-ion-cell-BMS-li/32718848125.html?spm=2114.13010608.0.0.VWZfWZ
The power wires and BMS sensorwires are connected to the BMS in the old controllerbox.
The BMS is fixed vertically on the inside of the cover of the box.
The controllerbox is made of multiplex and fixed on the backseat carrier.
It is made like trapezium.
In the inside of the controllerbox:
- ignition lock (frontside)
- 12 FET IRFB3077 Infineon Controller (EM3ev.com)
- 48 to 12 volt converter (5 amps) for relais and light (H1 halogeen headlight)
- 5 x relais switches: controller, brake, brakelight, light, high/low beam
The Grace One is now a Grace One Plus.
All the mechanical and estetical benifits are present.
A complete new electrical design: more power, flexible, standard and cheaper
Max speed 60 km/hr. Limited to 45 km/hr.
I like it.
I like it.
