whatever
- Joined
- Jun 3, 2010
- Messages
- 1,297
whatever said:any ideas why pins 32 and 33 are shown on the flash programming diagram? must have some relevance.......maybe not
Yes, you can beef up the shunts by applying a thin layer of solder on each until you reach 45 amps.michaelkramer11 said:I recently received my 15 fet 4410 45amp controller. I am only getting about 36 amps peak from the battery. Is this something that can be easily adjusted?
Truusje79 said:michaelkramer11 said:I recently received my 15 fet 4410 45amp controller. I am only getting about 36 amps peak from the battery. Is this something that can be easily adjusted?
Hi Michael, I ordered a 24 fet controller some time ago from Greentime ( Leo ) and I thought it was low powered too, I asked for a tuned down controller, because it's tucked away without some air cooling so I asked Leo to tune it down from 80 to 60 amp for cooler running, it put out about 46 amp max, but then I bridged a 3 wire plug ( for 3 speed switch ) and now it does 58 amp....close enough for me, maybe your controller has something like this too and you have to try to bridge 2 out of the 3 wires of that plug, unfortunatly I can't remember the color of these 3 wires.
Anyway unbridged was about 75 % power, and bridged between 2 wires was either 50 or 100 %
Try it, maybe it works for your controller too without soldering the shunt or doing other mods.
