Wolfcub
- Joined
- Aug 8, 2014
- Messages
- 3
Hi everyone! New member here: thanks for letting me in! Am currently trying to conclude my first rear hub motor conversion of a Cannondale SL5 with the excellent assistance of another member. On this note, I've got a question.
Planning to run turnigy 6s lipos initially to 12s3P. 48 v, 15 ah. Is there any way to wire packs together so that they can be 12s3P under load but at the same time 6s1p for parallel balance charging purpouses without having to rearrange plugs? Think double harnesses with a bunch of diodes here and there to prevent the thing from shorting out and go nuclear on me...
Say I parallel 3 packs. Red bullet connector to red, black to black. 3 JST wired to one. I would then effectively have one pack of 24 v 15 ah. I could connect it to controller for biking and to my parallell charger directly without rearranging plugs.
Add another identical setup. Now what? Can diodes (or something) block DC one way so I could have the 4 main leads wired BOTH in serial AND parallel in the same harness, one plug to controller, one ready to recieve my (hopefully) trusty iCharger 3010B? Maybe even a third for bulk charging since I guess I couldn't bulk charge on controller leads any more. If so, what about the JST's? Would it be sufficient to block lead 1 and 7? Or even one of them? Or would I need to add diodes (or something) to all leads everywhere?
If it's not doable or the question is too stupid to even consider, go easy on me. I'm a noob without much experience in most fields, dc electronics most particularly. But wouldn't it be rather nice to be able to charge, run and parallel balance charge without having to rearrange a bunch of rather flimsy plugs? Just two plugs in, one out and one jst. Everything married together. A mormon lipo harness. :wink:
Cheers,
Wolfcub.
![Question :?: :?:](/sphere/data/assets/smilies/icon_question.gif)
Cheers,
Wolfcub.
