Grin all axle full kit (new) 52 volts
Shauno
Just purchased but decided to go another route.
Installed and ridden once but realized it’s too much power for me :-0
Basically brand new
All axle front hub motor laced to 650b dt Swiss rim
V4 Phaserunner L10- 50 amp controller
V3 cycle analyst
Torque arm
Torque sensing bottom bracket with crankset Erider
Em3ev triangle battery with bag (52volts) 1 charge to 80%
Charger 2 stage
Headlight 1900 lumens
Throttle
Aux button control
And all connections and wiring including qr & 12mm thru axle end caps for the motor.
I can remove the motor from the wheel if you prefer to use it in another wheel size.
Shipping available
Located in Vancouver Canada
Looking for $1900 CAD
Not looking to separate unless someone wants the battery and someone else wants the electronics :)
<snip>
V3 cycle analyst
FWIW, there are a number of easy ways with that CAv3 to fix the problem (and customize systme behavior in various other ways as well, to suit your usage needs). That's really the main reason to use one. ;)
The PR can also be setup to limit things to control for specific behavior, etc.
