AF7JA
I recently completed a build with a Grinfineon 25A a Cycle Analyst and a TDCM IGH. I have taken it on a couple of test rides and it was working.
Today, I went to go for a ride and when I applied power there was a shudder fro the motor and since then I have had no response to the throttle and a blinking red light on the controller. A couple of times, the cycle analyst said that I was pulling power when I applied the throttle, but that was the only indication that anything was happening, as a response to the throttle.
I did not first think the shudder was anything (and it may not be) because I had that on all of my rides if I tried to apply power when moving "too slow," as in, from or near a stop. It may not be connected to anything ad may be normal operation, all of my e-bike experience, to date, is a geared front hub motor and a couple of different mid drives, no direct-drive motors at all.
I unplugged and replugged everything. I removed the cycle analyst and then, seeing no change, reconnected it.
As it stands, Everything is reconnected and there is no throttle response, and no forward power or noises. I do note that the controller is quite warm to the touch. The motor is cool to the touch.
