hall connection
GTK
10 µW
france
Good morning ! I changed the sabvoton 72150 controller because I had problems on my chinese enduro 12 k, I put everything back together and it worked for 5 km, then 13 flash hall errors, maybe that was the fault from the start and not my controller. But my question is this, 2 motor hall cables are connected, can I use the second instead of the first? I took a photo on the left of the second original connector on the right of the first connector that I had to adapt with the controller received. I checked all the wiring everything seems ok. If the second take works that would be fine for me.
Yes, only one is usually needed in normal operation. The reason QS has two is that the 2nd one is a backup. To install one yourself will take 10 hours. A pro in less time of course.
