Hall Plug has 12 Wire not 5 or 6
Toronto
I need a 60V controller but my Hall PLUG has 12wires not 5 or 6 cant find one It's a GIO Titan Premium going from 48V to 60Volt
I think that plug incorporates the wiring for the 3 speed switch, so you will need to trace the wires to see where they go.
Are your pics of connectors directly from the old controller or the wiring harness?
You may have already done this but looking at the online videos for motor and controller replacement as well as comparisons between the standard and premium models, that doesn’t appear to be the hall sensor connector, but one for accessories or other functions.
Can you provide pics of the existing controller that clearly show each connector and wiring? You could do a continuity check between your 12 pin connector and the hall connector at the motor to confirm whether or not the 12 pin is for halls as you guessed.
