redorblack
- Joined
- Sep 26, 2009
- Messages
- 142
I'm hoping I haven't really damaged my pack... it's the 16s battery with headways BMS. It's started cutting out at shorted ranges than expected and the other night the charger started fast flashing at me. I opened the case and the glue holding the cells in had failed so the cells/holders/bms came right out. I figured I'd start by checking connections and found a couple of screws on the tops of cells a bit loose, so tightened them up and put it back on the charger while I went to get a volt meter. Came back and the charger had switched it's green LED on... I figured, "Great!". Except I checked cell voltages and most are around 3.65-3.67v... with one at 3.38 and one at 3.5v. Left the charger on for hours and would check voltage on occasion... I don't have my graphing meter at home so can't 'see' the charger cycling. All the cells came up to 3.67-3.68 except the one at 3.38 only came up to 3.40-3.41. Leaving the battery off the charger for about 6-8 hours and the other cell dropped back down to 3.5. Plugging the charger back in and in the amount of time it's taken to right this so far, the cell at 3.50 has risen back up to a reading of 3.60v while the one at 3.38 has risen to 3.40 (measured with charger plugged in).
Look like I need to replace the two cells, or one, or should I try finding a single cell charger and hitting just the weak ones? Or run it down part way or until lvc and see what cell voltages are at cutoff?
I sure was hoping to get years and years of reliable power out of this unit. I don't know if it's the vibration, or thermal cycling, or just poor assembly that caused the loose screws and if those are a red herring and it's just random cell failure.
Any input from the gurus?
Thanks,
Scott
Thanks,
Scott
