[$129 plus shipping, USA BASED] 48v 19.2ah 920wh 60A Li-Ion Battery 3200 mAh cells, 13s6p
Good morning I just sent you a DM on these batteries, hoping you still have some in stock. I am trying to power a 48V 2000W Vevor system on my MX500 and keep reading a lot of good feedback on the SCUD packs.
They are good batteries, I got two from him. They can do about 33A each so I run 2x in Parallel for a 65A draw on my SX500 and Vevor 1800w.
Has anyone take. This apart to access the BMS?
Earlier in this same thread there are pics of the insides starting here
Is there a problem with your battery that requires repair?
Have you repaired batteries before? If not, keep in mind it is possible to short things inside them that can cause a fire if you are not careful, and it can require specialized equipment to do the testing and repair work depending on what exactly is wrong.
I got one from him that does well. The first post says 60A continuous 90A peak though, is that not right? If you say they can only do 33A each that may not work with the Vevor 2000w kit I just got. Wish I got 2 batteries :confused:
My battery was stolen in the mail 8 days ago seller has not recompensated me
well isn't that special. How on earth is the seller responsible for your unsecured delivery address? Jeebus
perhaps that's what the cells are rated for but from my experience, if you run these at more than 35A, the voltage sag will trip the BMS... For the price, you really can't beat it. 33A will still work with your Vevor kit, in fact your controller is the limitation above 30A anyways.
Makes sense. I'll see when I get it all wired up! And get another one of these batteries when they come up for sale again and run them in parallel.
Seller sent me a 15ah battery instead of the 19.2ah I paid for. A month later and I still haven't been refunded the difference. Beware!
Have you tried to contact him? I had an issue with mine and he sent me another battery for free... Great seller, no issues here. I've bought half a dozen of them.
Yeah I also received a 15ah battery instead of a 19ah. I figured out what the case looks like on these and bought one on eBay for $100. The case said 19ah and I was stoked it would match the one I got on this website from American electric solutions. Received the battery, popped the outer case off (very difficult to do btw) and the actual battery said 15ah. Bummer. Turns out the battery dimensions are exactly the same but the 19ah has more cells? Anyway, I weighed both batteries and they are exactly 9lbs 10oz which confirms to me that the original I bought off this site is also a 15ah. I thought it was fishy the battery spec decal was removed prior to sending me the battery. Maybe he got it that way, who knows. Either way, I got hosed buying both lol. BUT, the silver lining is I can run both in parallel on my Razor and still have plenty of range.
Looking up the cell types, there is roughly 5g weight difference between the higher 3200mah cells and the 2500mah cells which equates to slightly less than a pound difference between the 2 which is definitely not what I'm seeing.
damn is that why my decals were removed from my batteries as well when I bought the 19ah ones
Hello again everyone, here's another battery deal that we are offering. We have about 30 of these and they sell out quick.
Identical size to the 15Ah one that I listed on this forum, just higher capacity cells.
Let me know if you have any questions.
Full specs and pictures below:
Condition: New, never used (batteries were stored in a warehouse since november 2022 so some degradation is expected, but not more than %5 or moneyback guarantee)
Manufacturer: SCUD
Enclosure and protection: Hard industrial plastic, scratch and impact resistant. Honeycomb cell holders and anti-vibration silicone between cells to reduce damage overtime. Water resistant silicone insulation. Metal screws holding together the cell holders and hard plastic shell)
Length : 9.87 inches ( 9 and 14/16 or 25.08 cm)
Height: 5.62 inches ( 5 and 10/16 or 14.28 cm)
Width: 2.81 inches ( 2 13/16 or 7.13 cm)
Weight: 8.7lbs
Voltage: 48v
Capacity: 19.2aH
Watt hours: 921
BMS: 60a (Low Voltage/Overcharge/Temperature/Current output and Short Circuit protection, power equalization output)
Discharge rate: 60 amps continuous 90 peak (920 continuous or 1400w peak)
Max Charge rate: 4a
Limited Charging Voltage: 54.6V
Charging time: 5 hours
Cycle life: ~800-1200 full charge and discharge cycles (gentle use) or 500-800 cycles if used regularly
Configuration: 13 series 6 parallel
Cell type: lg 18650 mh1 3200mAh
Amount of cells: 78
Chemistry: Lithium - Ion
Connectors: xt60 + 2 pin for battery meter
Does not come with a charger
View attachment 336862View attachment 336863View attachment 336864
Do you have any of these
Do these include shipping? And do I need 2 to run 60a?
Manufacturer: SCUD
Weight: 8.7lbs
Voltage: 48v
Capacity: 19.2aH
Watt hours: 921
Max Charge rate: 4a
Amount of cells: 78
