Tommy L
MD. said:Thank you Jimmie for running these tests and posting the results!
Although they can handle sustained 10C, the voltage is low.
This is why I build the Headway packs with 2C max in mind if I want to maintain a certain
voltage. They don't sag at 2C. I find they work great. The main complaint is most see
the HOC at 3.65 or 3.7v per cell, then they load it and see it go to 3 or 3.2v per cell
and call it sag. They will stay at the 3.1 or 3.2v per cell under a 2-4C load until
100% capacity is used. On my test, I've noted that they go a little beyond the
rated capacity before that 3.2v falls off a cliff.
If we build packs to keep the stress off the cells, both you and the pack will be happy :wink:
Tommy L sends....
