Jason27
Jim, How about some compensation from headway? Send choot a new pack.
Did Headway assemble the whole pack? If not, it's not their fault and is up to the OP's conscience to blackmail Headway or not. My guess is they will give away a new pack. Not because its their fault, but just to hold user's anger low to keep this fire below mass public's level. Because the PEOPLE (as a group) are stupid and will never go to deeper understanding what went wrong - bottom line "HEADWAYS BURNED". Its always the end manufacturer who gets harmed. Just like sellers on ebay - no warranty or protection from any customer screwing with you.Jason27 said:Jim, How about some compensation from headway? Send choot a new pack.
etriker said:Ouch ! A battery pack builders nightmare.
Are you recalling any packs ?
grindz145 said:Huge bummer man, glad nobody was hurt. Thanks for sharing. Sorry to hear!
In the end IMHO, it's the BMS' fault. One was or another, the cells were abused, and the BMS aught to not allow it to happen, with multiple tiers of protection, or else why even bother.
amberwolf said:I suppose all this boils down to "resistance is fusile"?Jeremy Harris said:The power loss from even 16 fuses is going to create a fair bit of heat, and add to the heat load right where you don't want it. Even 20 to 30 watts of extra heat inside a pack that's well protected is going to heat it up, and lose power.
(sorry, it's not a perfect joke, but I'll not likley get as good a chance to use it any time soon)
etriker said:Hobby King RC lipo wiring is fuses.
Ykick said:etriker said:Hobby King RC lipo wiring is fuses.
Like majority of your posts, wrong. Turnigy RC Lipo relies on PCB traces to act as fuses and it works.
@chroot - sorry to hear about the loss of your pack but glad no one was injured.
We deal with a lot of potential energy here folks. Whatever your chemistry of choice nothing is 100% safe or immune from flames so best plan and park/store accordingly.
etriker said:Ykick said:etriker said:Hobby King RC lipo wiring is fuses.
Did not know that. Thanks for clearing that up for me.
Sorry for all the confusing and misinformed newbee like posts. I will try and not post so much. The only reason I jumped back into the ES mess was so I can pm people that have stuff for sale. Will shut up now.
etriker said:Had I built that pack I would recall it.
I would want it back to look at and study.
Trying to figure out what happened with pictures would be a nightmare. I would want to know.
circuit said:After pointing out the charge wire... The wire shorted out, no fuse on it... The pack is too weak (headways are quite crap, my testing shows) to burn it away as a fuse, so it heats up badly... The plastic tray melts right off, many wires and cells short together... And here you have it.
Also it looks like most or all of the burning is not from cells, but from that crappy plastic array. And this one is on headways, as they did it from wrong plastic.
Whoa whoa, dude, calm down.JimmieD said:circuit said:After pointing out the charge wire... The wire shorted out, no fuse on it... The pack is too weak (headways are quite crap, my testing shows) to burn it away as a fuse, so it heats up badly... The plastic tray melts right off, many wires and cells short together... And here you have it.
I may have misunderstood your post, but I completely disagree with you that it is on Headway, and that 'they did it from wrong plastic'. I am not here to create a debate or argument, but my name is on that battery build as well as many others out there and I will not stand by to be told that I did it from the 'wrong plastic', whatever that means. If referring to the plastic cell holders as the 'wrong plastic' what would be the correct plastic? And is the 'correct plastic' cost feasible for not only manufacturing but also distribution to consumers? And would consumers be willing to pay for it or would they have 'sticker shock'? Please enlighten me so that I can look into it.
You say the charging wire first shorted out, that is the first culprit, now the real question should be (IMHO) HOW did it short, rather than jumping to no fuse, Headway cells are weak and would not burn a fuse away anyways, thus causing the plastic to melt, which in turn melted everything else and shorted it....did I understand this correctly? It is easy to be an armchair quarterback, and from your post it is apparent to me that you have a distaste for Headway cells and have let your views dictate the outcome of your synopsis.
Just working through all the various scenarios to see if it leads to something else or creates a dead end, and to help with educating those who are reading this including me! :wink:
About the fuse... There isn't any on charging line. And that's your fault. I guess that a low power charger was used, so 10 Amp fuse would have been enough to hold the current and to blow if there is a short.
This seems a good summary of the situation. My experiences with the Headway mounting system, etc are similar, although I might add that the Headway end blocks are effective components but not a complete mounting system in their own right. I would recommend a plywood or other hard/rigid base to bear the weight evenly and prevent localized stress points due to uneven or soft (e.g. foam) support that might cause the somewhat brittle Headway end spacers to fracture. While intact the mounting system is rigid and offers good spacing/insulation between cells.Alan B said:These cells, at least the ones I have, are very tight into the plastic blocks and require force or tapping with a mallet to seat them fully. If there are restraints to insure the plastic blocks can't vibrate off the cells then they are restrained pretty well, at least for a small pack like this. If you had one several feet long then more external support would be required.
If a low impedance short is not interrupted the batteries can become so hot as to melt the plastic supports and form new shorts locally inside the pack. This is not the cause of the problem, it is an effect. Improving the support system is nice but not the first priority.
Jeremy Harris said:I agree, plus the maxi is quite a good fuse in terms of minimal resistive loss - just 1.2 mohms for the 50 A rated one. Add in that they are readily available pretty much all around the planet and they seem to be a good choice.Alan B said:Judging by the appearance of the fuse itself that is likely a MaxiFuse.
The MaxiFuse is also the only one available in a high enough voltage rating for this application.
I used a couple of these in the same holders as used by chroot to protect my two Headway 8s2p packs and just removed them yesterday. Although the fuses themselves are attractive for the reasons stated, the fuse/holder assembly is not so good.Alan B said:The fact that the main fuse was blown open indicates that circuit was shorted late in the event, after the fire was already started, or that the main fuse somehow failed to blow fast enough to prevent a fire.
cal3thousand said:Would treating parts of the pack in this stuff help at all?
http://www.ebay.com/itm/New-FLAME-RETARDANT-SPRAY-ON-FIRE-PROTECTION-/370481627162?pt=BI_Security_Fire_Protection&hash=item56426d001a#ht_3251wt_953
