Hummina Shadeeba
If I pass 100 amps at 1 volt through a resistor it’s the same wattage as if 1amp through a much bigger resistor at 100 volts, and heat is measured in watts so should be the same temp produced no? But only amps create heat.
Hummina Shadeeba said:But only amps create heat.
Hummina Shadeeba said:With high voltage power lines I understood the voltage was increased so as to have less losses in the long wires. If I’m calculating the losses in a 10 mile wire and let’s say it’s one ohm total and 10,000 volts and let’s say 100 amp are passed through... how many watts are lost as heat?
I^2R to decide power lost. voltage isn’t in the equation. Voltage is relevant in that greater voltage will allow more current but the voltage itself isn’t relevant other than that no? I mean in determining the wattage loss to heat. Thanks for your input and I generally know ohms law but as it relates to power lost in a resistor and the heat produced..while V x I is wattage..when figuring the resistive losses as a wattage voltage isn’t there and just relevant in how many amps it pushes.larsb said:Hummina Shadeeba said:With high voltage power lines I understood the voltage was increased so as to have less losses in the long wires. If I’m calculating the losses in a 10 mile wire and let’s say it’s one ohm total and 10,000 volts and let’s say 100 amp are passed through... how many watts are lost as heat?
Ri2 for the loss is 1*100*100 so 10kW out of the total 10.000V*100A of power is lost. efficiency of transfer is 99%
goatman said:you could try putting 100v 1 amp to your tongue
do you still have a tongue?
goatman said:if amps kill you not volts
but what happens if you get shot with 50,000 amps and 0.1volts?
Hummina Shadeeba said:..
Yea I get it but voltage isn’t in the power lost equation directly and it’s just current x resistance. that current is earlier decided by the voltage and resistance. Nitpicking. But still amps cause heat not volts volts just push the amps. Lost wattage to heat is a measurement of amps ultimately.larsb said:Hummina Shadeeba said:..
Yes, voltage is in the equation.
U=R*I is the first part of the ri2 as (R*I)*I
This voltage is the voltage drop at 100A due to the 1ohm resistance
I^2R to decide power lost. voltage isn’t in the equation. Voltage is relevant in that greater voltage will allow more current but the voltage itself isn’t relevant other than that no? I mean in determining the wattage loss to heat. Thanks for your input and I generally know ohms law but as it relates to power lost in a resistor and the heat produced..while V x I is wattage..when figuring the resistive losses as a wattage voltage isn’t there and just relevant in how many amps it pushes.Hummina Shadeeba said:Ri2 for the loss is 1*100*100 so 10kW out of the total 10.000V*100A of power is lost. efficiency of transfer is 99%
