I need information primarily on:
This is primarily for my son's MX650 razor, but I can see it being of use for others as well. I'll let you guys know if it works but there's a JT sprocket with an 80mm bolt circle pattern that is only about 1mm off from a common freewheel adapter available and if it works I'll share that info
I was currently just going to get it mounted then weld the freewheel in place to eliminate that function. I've upgraded to a 1800watt brushless motor on his razor.
We need kindof an eco system that will allow us to use many sprocket options. I hate the current buy this one sprocket that's expensive, buy this other sprocket that's expensive, hassle. I want to design one or two adapters from a freewheel thread or disc brake mount to a popular sprocket bolt hole pattern.
I'm trying to adapt 420 & 428 motorcycle sprockets. I've attached a plethora of picltures of JT sprocket dimensions to satisfy your curiosity.
I'm not sure the best way to go but I do know that when I want to order a 60 tooth sprocket I want to be able to get one quickly and cheaply. I don't want the hassle of searching the web for hours.
I'd love your help to figure some good ecosystem out, and to spread the knowledge as far and wide as possible
- sprockets
- freewheels
- sprocket freewheel adapters
- focus on threaded adapter? more robust than disc brake adapter? Worth the extra cost? This would need work on a CNC lathe or mill
- focus on disc brake adapter? This can likely be just laser cut from a thick sheet of aluminum and could be very cheap. sub $10/piece at high enough volume. Can be plasma cut, waterjet cut, lasercut, etc. might even be able to make one myself on a CNC router!
- find current off the shelf solutions and piece them together?
