markz
100 TW
<<<<^^^^What he said back there!
+1 for Direct Drive's!
MadRhino said:I like the motor on the rear because bikes and horses and anything that you ride, are best rides with powerful hind and light handling front.
MadRhino said:As you can see now, different riders and different builders have different opinions. You will have to make an idea by yourself after considering pros and cons.
A 15 yr old quality bike, is 100 times better than a brand new piece of sh*t that will never be good should you upgrade it indefinitely.
Pay 4 or 5 hundred bucks on an old bke that was 2000$, and with maintenance/tuning you can make it ride better than a 3000$ bike that you’d buy new today.
I like DD hubs because they last, and survive amazing abuse. They are upgrade ready, for you can feed them many times their rated power. They are minimal maintenance because they are built with few parts, no clutch nor plastic gears, no toy size motor that has no contact with the outside to shed the heat.
One thing I know, is that anything people build, they like riding. But I also know, that most had never had a chance to ride a good bike. I mean a good bike by the standards of a rider who had tried hundreds of bikes in many riding sports. Give yourself a chance, avoiding like sh*t any cheap crap wallbikes and such. Not because you can’t build an acceptable commuter with some of them, but because good horses are making better riders, who in return get to know how to tune good horses. :wink:
Thanks Wturber--I think that makes a lot of sense to me. Especially sports car vs sedan--it's easy when reading these threads on a build to get caught up in how cool a build is and not think about what practically will make the most sense. I think DD fits my needs pretty perfectly.wturber said:MadRhino said:I like the motor on the rear because bikes and horses and anything that you ride, are best rides with powerful hind and light handling front.
I usually stay out of the discussions on handling because "handling" can mean such different things to different people in different contexts. But MadRhino's comment about a light handling front resonates with me. My bike is very rear heavy. I've got a heavy DD motor and I hang my batteries on a rear rack. My bike is a hardtail and I think that makes for a good commuter/car replacement because you its easier to hang a lot of stuff back there. And that, of course makes the back heavy. I've got a modified milk crate on the back of my bike now and I've loaded it up with 28 16.9 oz bottles of water a number of times to re-stock our water at the studio. That's about 30 lbs. My rack mounted batteries are 20 lbs, and then there's the hub motor itself that weighs about 15 lbs. So the bike can get very rear heavy and the front remains light. But even with 65 lbs the bike handles fine in that it is stable, easy to steer and stop fast and predictably. When I add some weight to the front by carrying stuff in the front basket, that tends to affect handling way more than adding it to the rear. I think of my bike as being analogous to a large sedan or a small truck. It is not a sports car. The Chas58 bike is more analogous to a sports car.
A heavy rear hub is just fine for a commuter on flat ground. For your purposes, I think the main reason to consider a geared hub motor would be for the better ride-ability when you have no power and somewhat lighter weight. Even so, I'd put that motor on the rear. The rear gears and possibly the disc rotor tend to disguise the presence of the motor. But if you are legal and riding legally, there's not a whole lot of reason to hide the motor IMO.
I like the brand, frame size and the space in the main triangle. Some people will knock it for not having disc brakes. You can search the forums for tons on that debate. For your intended speeds, the caliper brakes should be fine with the right brake shoes and perhaps with some brake boosters. Speaking of the brakes, make sure your kit has a brake shoe compatible wheel rim.reluctantsuburban said:Would anyone be able to weigh in this Trek Fuel 80?
https://dallas.craigslist.org/dal/bik/d/trek-fuel-80-full-suspension/6711453532.html
wturber said:I like the brand, frame size and the space in the main triangle. Some people will knock it for not having disc brakes. You can search the forums for tons on that debate. For your intended speeds, the caliper brakes should be fine with the right brake shoes and perhaps with some brake boosters. Speaking of the brakes, make sure your kit has a brake shoe compatible wheel rim.reluctantsuburban said:Would anyone be able to weigh in this Trek Fuel 80?
I know nothing about the quality of the suspension or how the rear suspension will work with a relatively heavy DD motor. But given that your intent is simply to absorb road hazard bumps, potholes and the like, I'd think it would be fine. Hopefully some of the guys who know more about suspensions will chime in.
It will take a bit of fiddling/cleverness if you want to add a beefy rear rack for hauling stuff. The same might be true for fenders if you decide to add them. I'd also point out that the flat handlebar has a fairly forward stem. I'm imagining your riding posture may be less upright than many people would prefer. Though you are a bit on the tall side, so it may be fine. Just something to think about.
The price seems right. But be aware that you'll probably spend money on brake shoes, brake boosters, maybe a new stem or handlebar, seat?, new chain?, maybe larger chainring? Maybe some slick road tires that are better for commuting. Just pointing this out as these things can creep in and affect your real world build budget.
motomech said:reluctantsuburban said:Would anyone be able to weigh in this Trek Fuel 80?
Good donor bike, especially if it is in gd. shape(looks like it)
21.5" frame is what you want, at 6'1", no prob. w/ stand-over height
LImited 3" suspension travel, but enough for the street.
Fox Float is solid unit, you will need an air pump. Rebuild kit is cheap and easy to install.
Big frame triangle means Falcon or Em3ev frame bag will fit nicely. Will need a guard(plastic)to keep bag from rubbing on shock.
Forks have disc caliper mounting lugs, I would install mech. frt. disc
Will need steering stem extender to raise H.bars
Seat stem mounted rack(no stays)and keep the load lite
Maybe clearance for 48T frt. chain-ring(has 44T now)
Gear-set/shifter ok for ebike. cassette has 11T sm. gear-good
wtuber has gd. point about kit rim possibly not being compatible w/ rim brk.s
I would use Ebay geared mini motor kit I linked(OP keeps calling it DD, it is GEARED) on frt. whl. to save on extra money needed for DNP free whl. and spend rest of money on 48V or 52V(if compatible w/ kit controller?) triangle batt. & bag and tires(WTB Slicks{they have tread}w/ flat guard
Controller, extra wires and connectors can go in frame bag making install clean and easy. Big size of kit controller means it won't over-heat
W/ Fox shock equipped bike this cheap, there is absolutely no reason to go hard-tail.
Frame bag in 21.5" frame;
markz said:https://knowyourbike.com/trek/fuel/80
2001-2006
6 versions
reluctantsuburban said:Hey wturber--thanks again for your feedback. Very helpful. The rear rack seems like it may be a challenge, as that is something that I don't think I can commute without.
I think you are right on listing out all of these extras, but considering what a deal I am (potentially) getting here on the bike, I think I can justify the upgrades. Do you know how I would evaluate how large of a chainring I can fit? And do you have tires that you would strongly recommend? I have seen Schwalbe Marathon Plus really consistently recommended here.
I have used both and prefer the WTB. It's a much newer design and the flat guard layer is thinner, which means less of a "squirmy" feeling flat-guard tires impart. I combine w/ the Forte extra thick tubes, so some of the squirminess is still there, but it's worth it to not get flats. Here in Az. we get goat's head thorns washed into the road after a monsoon and this combo resists them very well. The compound is softer than the Marathon, which is great in the wet, but they probably will wear faster. Haven't had mine long enough to know. Above all, they look koolI think a front disc, air shock rebuild kit, and air pump are all reasonable. You prefer the WTB Slicks over Marathon Plus? That's what I have seen recommended most frequently so far.
There are ways. They make rear racks for suspension bikes, pricey. dogman uses stem mount rack and fabs a pair of supports. It is not a difficult mod. Search his postsDo you think I could get away with rigging together a rear rack with some p clamps? I really like my current pannier set up--if I could retain it that would be ideal.
The description for that kit is fairly detailed and when it doesn't say "rim brake compatible", I think it is safe to say it is not. I have never had rim brk.s, but I think the difference is the angle of the rim side, hard to know from pic. Maybe someone who knows rim brk.s will chime in.Would I just reach out to the seller on ebay to ask on the to ask about the rim break compatibility? Or is there a way for me to visually confirm?
There are two types of rear gear-sets, a Cassette, which fits on a spline, and a free whl., which screws on the threaded nub. Look at kit pic and you will see the threaded nub. Also, in the foreground, you will see a free whl. The problem w/ the one shown, the smallest gear is only a 12T or 13T. Only the Enoch DNP (about $40 w/ shipping) comes w/ an 11T gear. Every bit of high gear you can get is important if you want to pedal in the mid 20's mph. There are a few hub motor that accept a cassette, BPM C, Q100 C and Q128 C. But Q100 C does not come in mid-speed(260), which rules it out for your build. Many here consider the DNP a necessary evil. They are heavy and somewhat course. I don't mind them, except for the cost and the fact that they can be hard to get off once they have used(pedal force tightens them on the hub)....I don't understand the purpose of the freewheel. I need to install that on the front wheel where I would install the hub motor?
Except for trying it, you can't. Both of my bikes, the 48T just clears the chain stay. If you have to go w/ a 46T, you will only be out 15 bucks or so.Finally, how can I tell what size crankset/chainring will fit?
Kinni420 said:Meh...mid-motor go go. bafang bbs02 kit with everything including battery. $888 from Lunacycle. Ill never ride a hub motor again.
motomech said:Wtuber posted while I was typing.
The Q100 mini is a little smaller than the Ebiking mini, but, as you can see, the difference in size between a DD and a mini geared is profound!
Kinni420 said:never ride a hub motor again.
MadRhino said:The price is fair. That is what a 2003 Fuel is worth in average condition.
markz said:MadRhino said:The price is fair. That is what a 2003 Fuel is worth in average condition.
Yes but haggling is always fun. Start well below but dont insult the seller.
MadRhino said:Fair $120 - $123
